Running OCCT it throttles regardless of if it is overclocked or running stock.
Specs:
MSI fm2-a75ia-e53
A10-6800K
G.SKILL 1866 ram *(I've tried running the ram at diferent speeds to no avail)
I'm using an all in one watercooler and it will boot and run various things just fine at say 4.8ghz, however if I run OCCT it will run for a few minutes then start throttling down. Using the MOBO "Click Bios" and hwmonitor it shows the CPU temp is only 46-48c but it will start throttling as low as 46c.
The bios options are quite limited, I'm just trying to make sure I can avoid it while gaming in say BF4 or something like it.
I updated the bios to see if that would help and it seems worse. I've pulled the cooler and replaced the compound, I'm thinking the bios is reading the cpu temp right?
Specs:
MSI fm2-a75ia-e53
A10-6800K
