Belts are as follows:
Blue = 5 points - although all but one of these points were earned about 15 years ago.
1 point for each class of CPU overclocked.
AMD Athlon XP to Barton. - second or third PC build, first one that I researched and purchased from the ground up. Athlon XP 2500+ (Barton) overclocked to 3200+ speeds by running FSB @ 400mhz.
Any non-x86 CPU - Currently running Ryzen 2600+ with PBO enabled and voltage offset. Also tried to manually overclock the multiplier, but couldn't match the performance of PBO.
1 point for each other activity.
Northbridge cooling mod - replaced heatsink on Abit NF7 K7S5A for Barton build above
Video Card cooling mod - cannibalized the heatsink from a 1990s Pentium and cut it up with a hacksaw or Dremel (I don't remember) to make small memory heatsinks for the Radeon 9500 pro in the Barton build above. Funny story is one time I left my PC on and reached in to move a thermocouple, and knocked one of these suckers over killing the card in question. Replaced it with a 9800pro that got an aftermarket cooler and a bios flash to become a 9800xt.
Voltage reg cooling mod - used a similar process as described to place heatsinks on the mosfets of the K7S5A. They were later upgraded to purpose built copper heatsinks (shortly after the incident described above).
Lapping a CPU - not taking credit for this one, lapped the Thermalright SLK-947 cooling the Barton above. Does lapping an IHS count, I could do that to the Ryzen for a point
I just saw the updated rules on the first page. Does flashing a video card to a bios that was not intended for it count as a soft mod? If so the 9800 pro to xt bios is a point. Also dremeled a hole for a fan on the side panel blowing at the video card. So that would be Brown.
