I'm currently reworking a Dell E1505. I'm taking the screen for a car pc. I'd like to make this into a nice arm based machine. I'm looking at, http://www.overclockers.com/forums/showthread.php?t=659341 . It's 1.2ghz so it should have enough power. I might put linux or android on it. What I'd like is to make it into a gps/maps machine, with voice commands. I might just work with google voice actions, but really I'd like gnome speech or something similar. I'd like to setup to get internet via either bluetooth or wifi with my rooted hero (android 2.2, soon to be android 2.3)
The things I need:
Arm based device
GPU output/ someway to interface with the 15" screen.
storage (flashdrive/cheap hdd/cheap ssd?)
Method to power device based on 12volt circuit.
good quality microphone.
GPS device
Bluetooth/wifi chip.
audio output to stereo.
I have an El Camino, so fitting this all in the car will be difficult, the main issue is going to be the screen. I believe the rest I can work into under/behind the dash in places. I might have to make the screen hideable/stored flat and pulled out then flipped to be vertical.
Any ideas or advice would be much appreciated. I've never done anything such as this before.
The things I need:
Arm based device
GPS device
