- Apr 22, 2004
Hello,
I decided to start a new thread because I am really confused about something and cannot find an answer. In the past I wasn't that considerate of components and making them work to their optimal performance. I just plugged in things until everything worked.
However with this new build i've been a little more meticulous, and one thing in particular is really bugging me.
TBH I don't know a lot about how PC's actually work, even though i've been building/ocing for 15 years.
Here is my conundrum:
This MOBO has 3x m.2 slots, M2_1, M2_2, and M2_3. In the manual, there are different instructions for installation, here are the snippets:
* If M2_3 is occupied by a SATA-type M.2 device, SATA3_3 will be disabled.
Then on the following page for the other two M2 slots, it states this:
* M2_1, SATA3_0 and SATA3_1 share lanes. If either one of them is in use, the others will
be disabled.
* M2_2, SATA3_4 and SATA3_5 share lanes. If either one of them is in use, the others will
be disabled.
* Type 22110 M.2 module is supported with either M2_1 or M2_2 socket.
The one question I have is this: Will using a PCie M.2 ssd in thet M2_3 slot, effect my graphics card? Since it won't interfere with the SATA ports, is it taking PCI lanes away?
be disabled.
be disabled.
