uberterrific
- Sep 14, 2015
I have a I-5 2500k Intel Processor in a Asrock Z77 Extreme 4 motherboard running WIN 10 Pro 64 Bit. I have stable OC running at 4.2mhz. In Bios Version 2.09, should I choose OC b "per core" or "all cores"?? My PC shows that not all cores are at 4.2mhz..... Is there anything in the bios I should definitely turn off?? I also bought 2x8gb Corsair Extreme Pro DDR3-2400 RAM Memory for my Asrock Extreme 4 MB. The manual says it can use up to DDR3-2800. The bios however only gives me the option for up to 2133. Any Ideas???
