Ok I am going to assemble a gaming rig that is going to be playing MMOs and other basic stuff like Word/Excel. So nothing to extreme, but able to run games with high FPS, possibly 2 games at the same time. With high performance.
I have assembled a couple low end computer's but since im sinking a bit more money into this one i would appreciate more opinions and advice. Lots of things still confuse me! Thank you so much for the help guys!
CPU: No need for an i7, right?
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard:
This i could use some recommendations on. I am going to be overclocking my CPU obviously. What will meet my needs without being overkill?
Power Supply: Gold Certified is $30 more. Worth it? 750w Should be more then enough, right?
CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
or
CORSAIR Enthusiast Series TX750M 750W ATX12V v2.31 / EPS12V v2.92 80 PLUS BRONZE Certified Semi Modular High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139030
Memory: 1600, and 8gb is perfect for gaming?
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Video Card: Any other GTX 670 model better?
EVGA 02G-P4-2678-KR GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130787
Solid State Drive:
Help! I wont be putting anything on this drive except for my OS and a couple games. Should I get 2 60gb ssd's and Raid 0 them. Or would I be better off getting one 120gb ssd. I don't care about file security or losing files. I will have everything important backed up. Im talking purely for gaming performance and reducing loading screens and such!
Cooler:
CORSAIR H70 Core High Performance Liquid CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181019
Case: I'd like depth for cable management, good air flow/cooling, and easily removable fan dust filters if possible. Suggestions?
NZXT Phantom 410 CA-PH410-B3 Black Steel / Plastic ATX Mid Tower Orange Trim Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146092
Motherboard:
or
Solid State Drive:
Cooler:
