Sure, you can play some games. The limiting factor will not be the motherboard but your 8800 GTS video card. You will have to be selective with the games and not be able to run a lot of games on high res/high detail.
this 955 isn't the B.E. one, but I managed to get her to 3.9GHz before BBOD. This mobo automatically adjusts voltages and HT speed accordingly. I ran it at 4.0GHz but crashed after an hour of prime95
Already got that covered. At stock speeds of 3.2GHz the cpu is 1c above room temp (25c) and load wont budge over 40c. At 3.6GHz (my preferred speed) it idles at 28c and under load will go no more than 44c. I am using cpu-z, asus AI Suite for temps, and prime 95 for stressing. I'll post some cpu-z validations in a bitChirkk you should do the following, bring the cpu back to stock values.
Download the following programs to better monitor what is going on with your system.
Cpu-z http://www.cpuid.com/softwares/cpu-z.html
Hardware monitor http://www.cpuid.com/softwares/hwmonitor.html
Prime 95 http://www.mersenne.org/freesoft/
Run Prime 95 for an hour or two at stock speeds and make sure your temperatures are ok before you start overclocking. You want the cores to stay below 60c preferably 55c.
The post pics individually of the CPU tab, Memory Tab, SPD tab on the CPU-Z and also a pic of the HWmonitor under load. That way we can see where you stand and how much room you have to OC.
You might want to reduce your HT Link frequency. That one just plain doesn't like to be overclocked past it's stock 2000 mhz in that CPU family. Thuban core CPUs will but Denebs don't like it. Also, your ram is exceeding its rated 1600 mhz capacity. Right now you have it overclocked to 1760 (880x2) mhz. You might want to change the divider to lower that or at least give it some more voltage. According to the CPU-z SPD tab it will do 1676 (838x2) but look at the timings in JEDEC #3. You also need to relax some of those timings.
Yes, the HT Link frequency will rise with the increasing fsb (that's normal because the HT Link is tuned to the fsb frequency) but you may have you have an adjustment in bios for HT Link speed. It can be expressed as a frequency or as a multiplier. You say the only thing you can change in bios is the FSB? I would be surprised if that is the case. But a lot of adjustments may be hidden if you have settings on Auto. There may be a master overclocking mode adjustment that needs to be taken off of Auto and set to Manual in order to do more and then there will be subsections in bios that need to be taken off Auto and put on Manual to customize the values. For example, the memory or DRAM timing section.
