Just bought myself a new rig. Here's my setup:
MB: ASUS P6T SE
CPU: Intel Core i7-930
Disks: 2x Intel X25-M 80gb in RAID-0
Mem: 6x Corsair XMS3 DDR3 1600MHz 2gb CL9
GFX: XFX Radeon HD 5970 BE
Chassis: Corsair Obsidian 700D
Cooling:
Stock i7 CPU-cooler.
In my chassis I have one 140mm fan directed upwards from the bottom of the chassis(default in the 700D), one 140mm fan blowing outwards at the back of the chassis, and one 120mm fan blowing outwards at the top of the chassis.
Everything is set up and works, but the overall temperatures of the components are way too high. They are so so high that I haven't dared to run a stress test yet, but during half an hour of heavy gaming the GFX peaked at 91C and the CPU at 81C. My room temperature is ~26-29C. Idle temps are listed below:
Idle temps:
MB: ~54C
CPU: ~53C
GFX: ~60C
MEM: Unknown, but they are hot as hell when I touch them. Comparing it to touching the GFX I would guess ~60C
Room temperature: 26-29C
I found out using GPU-Z that the GPU-fan was only running at 30%, even under 100% GPU load. I had to upgrade to the latest BIOS on my Radeon card in order to get fan-control. I tried some gaming with the fan set to 100%, and the card peaked at ~70C, which is okay I guess, although the sound from the fan was unbearable.
I have also tried a lot of different voltage levels both on the CPU and the memory, and I managed to get the CPU to idle at ~47C with core voltage set to 1.1.
At the moment my rig is running without my chassis left side door, but the temps are the same.
When it comes to the CPU-cooler I have double checked that it fits perfectly. I also tried to remove the pre-applied thermal paste and replace it with my Arctic Alumina paste without any change in temperature.
Cable management should be good enough.
Am I missing something? I have played around with the BIOS-settings for hours and hours without any significant change in temperature.
MB: ASUS P6T SE
Cooling:
Idle temps:
MB: ~54C
CPU: ~53C
GFX: ~60C
