ASUS X99-AII Blinking Blue Lights?
RastusW
The PCI Slot clips on my mobo are blinking blue. Does anyone know what that represents or means?
I'm having trouble with playback on a Blackmagic DeckLink Mini Monitor 4k Card in one of the PCI slots.
Incidentally, the status code is AA.
Thanks
PC Specs...
Win10 64bit | ASUS X99-AII | i7 6850K @ 3.60GHz | 32GB Ram | GeForce GTX 1080 | DeckLink Mini Monitor 4k
That is a RGB breathing effect that can be changed in the bios menu bios>advanced mode>Advanced (tab)>onboard system settings>RGB effects. The AA code means you successfully booted into an operating system like widows.
+1 for peanutbudder.
mine do the same and clash very badly with my evga 1080 ftw cards when I fire it up.
Which pci-e slot are you using? If it’s in the southbridge slot (the one that doesn’t light up) you may have adjust the pci-e to legacy mode.
