safe voltage? do you mean stable voltage? If thats the case then only one way to find out.
trying for a underclock?
I think I remember people running like 1.0-.90 at speeds around 1ghz and above.
The processor he describes does exist. It's the Barton Athlon XP-M 2400+ (133x13.6=1800mhz). 45-53W TDP.
Lower multis are not always more stable. There's a sweet spot where you can run at the lowest voltage and remain stable. Anything higher or lower and it will become unstable without some more juice. It's rare for people to try lower and lower voltages. I am guessing you are going for power efficiency and low cooling needs (are you trying to passively cool an Athlon XP-M?) The only way to know is to test, it's different for every chip, but low voltages should be safe (in the sense of not hurting the chip) whereas high voltages can be dangerous to the chip (though you have to get pretty high). It might be unstable though.
you'd be lucky if such ccontrols exist
