- May 24, 2001
- Maine, USA
Waiting for my new case to arrive, TT W100 to fit the Nemesis 560GTX and EK 420 CE rads inside.
I need 7 140mm ($$$) fans for my quiet build. Very sadly, the Gentle Typhoon is not made in 140mm.
The final contestants are the EK Vardar EVO 140ER, Silent Wings 3 High Speed and the Noiseblocker e-loops. Preferably PWM.
Which offers the best balance between static pressure, quiet operation, quality and cost?
Would <=1200rpm be a too limited range for performance or should I at least go up to 1500rpm? 2000rpm for flexibility? The e-loops with PWM only go up to 1200rpm. W/O PWM function 1500rpm. Vardars with PWM 2000rpm. SW3 high speed with PWM 1600rpm. All will be controlled via software/speed profile.
7700K and 1080 Ti in the same loop.
Update:
I discovered the Corsair ML140 fans at Thermalbench. They very closely parallel the Vardars in performance, have great reviews, warranty, price per pair and a quiet bearing. Ordered.
Update:
