Ok this is a noodle scratcher, and I apologize for the long winded post.
The base setup is
AMD 2800+ Barton
Abit Nf7-S V2.0
2X 1GB OCZ PC3200 Platinum LL
BFG 6800 GS
SB Audigy 2 Gamer
I have had this setup running stable for the past few months, everything on air. The processor oced to 2250 MHz and the 6800 fully unlocked and oced to 400 /1075.
I got greedy and bought a TT Tide Water VGA watercooler... wanted to squeeze more out of the vid card. So last night I ripped off the stock heatsink and put the waterblock on and dropped some heatsinks on the RAM. I should also note that I switched out the PSU (was a raidmax 450W) and replaced it with an Antec TruePower 550W. All happy I booted the machine up and on the windows splash screen I started seen multicolored horizontal lines flickering. The temp of the GPU was in the 30s C... I quickly powered down, checked everything but the problem persists.
Troubleshooting.
1. Replaced stock heatsink & fan, same problem upon boot.
2. Tested the card in a different rig, normal operation. Ran 3dmark05 on stock settings and overclocking the 6800 and everything is fine.
3. Tested my 9700 Pro in the main rig, everything works fine.
4. Installed latest chipset drivers and updated bios, 6800 problem persists.
5. Uninstalled 6800 drivers, no artifacts, resinstalled a few versions of forceware and the glitches come back.
6. thought maybe it had something to do with the new PSU so I ran the GPU power from the other supply (running on a computer next to it) same problem.
At this point I am thinking it may be a software problem?? I am going to start with a fresh install of XP and see where that gets me, otherwise the only thing I can think of is to swap the PSU back out and test again... .has anyone else had an issue like this? any help is very much appreciated.
Thanks,
Max
The base setup is
AMD 2800+ Barton
Abit Nf7-S V2.0
BFG 6800 GS
SB Audigy 2 Gamer
Troubleshooting.
Thanks,
Max
