- Feb 1, 2009
- Illinois
It could be, but I don't know any other programs for ltc gpu mining.
Just so we're all on the same page, can someone confirm my understanding - are any of the following statements untrue?
BDB ran out of locks.
However, only on some 0.7 nodes. Others, perhaps nodes using different flags, managed it.
We have processed 1mb sized blocks on the testnet.
Therefore it isn't presently clear why that particular block caused lock exhaustion when other larger blocks have not.
The reason for increasing the soft limit is still present (we have run out of space).
Therefore transactions are likely to start stacking up in the memory pool again very shortly, as they did last week.
There are no bounds on the memory pool size. If too many transactions enter the pool then nodes will start to die with OOM failures.
Therefore it is possible that we have a very limited amount of time until nodes start dying en-masse.
Even if nodes do not die, users have no way to find out what the current highest fees/bids for block space are, nor any way to change the fee on sent transactions.
Therefore Bitcoin will shortly start to break for the majority of users who don't have a deep understanding of the system.
If all the above statements are true, we appear to be painted into a corner - can't roll forward and can't roll back, with very limited time to come up with a solution. I see only a small number of alternatives:
1) Start aggressively trying to block or down-prioritize SatoshiDice transactions at the network level, to buy time and try to avoid
mempool exhaustion. I don't know a good way to do this, although it appears that virtually all their traffic is actually coming via
blockchain.infos My Wallet service. During their last outage block sizes seemed to drop to around 50kb. Alternatively, ask SD to temporarily suspend their service (this seems like a long shot).
2) Perform a crash hard fork as soon as possible, probably with no changes in it except a new block size limit. Question - try to lift the 1mb limit at the same time, or not?
Only because you can't get Bitcoins in our out of Magic the Gathering Online Exchange, but you can put in filthy fiat US dollars to buy what is already in the system. If you could get them in/out, it would have gone substantially lower, and probably will once it gets re-enabled.yeah that caused a nice dip in the price yesterday but people bought it right back up
