- Feb 9, 2012
- Miami, FL
I wanted to make a windowed side panel for my phenom build but something I've noticed is many people use either the double-sided clear tape, rivets, and u-channels when making the window. How could i make a window that's flush with the panel or at least without u-channels but as close to the metal as possible? So far I was thinking using 3M 4010 Tape, placing the panel behind the hole i cut and there but I am not sure if the edges will look flush/smooth.
I would basically make the window like this size and shape wise:
but would want the edges to look like this window:
Any help or suggestions would be appreciated
