- May 10, 2009
Unfortunately the first thing we discovered was that the shop's DSL modem/router had suffered an internal firmware failure and the internet was out of reach. Hence, no stream.
We did, however, get some decent results.
We used TJ's M4E and 2600k and Dominator GT ram. My Koolance LN2-V2 pot.
My Zotac GTX580 reference. Conformaled and with a coldslow bios, but otherwise unmolested. It had a KPC Tek9Fat (new, sealed with aquarium silicone) pot.
Temps on the CPU never budged from -74*c to -77*c.
Temps on the GPU ranged from -75*c at idle to as warm as -63*c under Heaven loads at 1.32vGPU. Pot mount was dubious (level, but the TIM didn't flow when I warmed it up. Don't know why), which may have held us back in the GPU clock department.
TJ was in charge of his CPU/mobo, plus stirring the pots.
I fed dice to the pots and ran the OS/benchmark end of things.
All told we burnt around 20lbs of dice.
3d01: 121756
3d03: 135772
3d05: 53012
3d06: 38402 Heartbreak here, my 41,xxx screenshot got murdered
Vantage: 34974
Aquamark3: 425756
Heaven: 2005.45
Many thanks to TJ for his help, stirring and feeding two pots by myself would be a damn good trick.
Also many thanks for the use of his golden CPU. It's amazing what raw GPU speed can do
3d01: 121756
3d03: 135772
3d05: 53012
Vantage: 34974
Aquamark3: 425756
Heaven: 2005.45
