- Oct 15, 2009
Hello guys, i have a problem with 4 ram sticks of 1GB Kingston Hyperx 1066 ddr2, according to kingstone documentation these sticks should be able to run at 1066Mhz with 5,5,5,15 timings at 2.2 volts, and they do, at least when i set them at bios and for the next hours of gameplay to come, the problem comes until the next day when i boot the computer, sometimes it just start to beep continuously and restarting itself and sometimes it loads in to windows and then a BSOD screen (0x0000003b mostly) then i need to reseat the sticks, go in to bios (it shows an error with overclock settings) and start again, then i can play all day until the next day when it does it again. As aditional information the computer is NOT overclocked, i switched the motherboard thinking that was the problem it happens on both MOBO's both Gigabyte one is a EP45-UD3L and the other one is a P43-ES3G.
Specs as follows:
e8400 core 2 duo 3.0Ghz
4 sticks of 1GB RAM ddr2 Kingston HyperX 1066Mhz
EP45-UD3L or P43-ES3G
GTX 460 768MB DDR5
PSU CoolerMaster 600w Extreme Power Plus
HDD Seagate Barracuda 500GB
I already ran Memtest with no errors, prime 95 (Blend test) with no errors, and played with BIOS settings time after time with no luck.
Almost forget to mention but the sticks are practically the same model KHX8500D2K2/2G, i got a pair first and then got the other ones, only difference between the two pairs is that one of them reads: 99U5315-053.A00LF and the other pair reads: 99u5315-043.A00LF.
Any help would be greatly appreciated.
Specs as follows:
GTX 460 768MB DDR5
