braveblades
- Jul 24, 2014
Hi,
First of all, i say hello because i'm new in this forum
I'd like to build a new PC for myself. The maximum budget is ~2200 USD
I want the PC to be able to achieve 3 main features:
- to be as quiet as possible (within the specified budget)
- to carry out a great performance in 3d/2d graphics tasks and high-end
gaming
- to be stable in overclocking (at reasonable values)
Currently I've chosen the following components:
Processor: Intel i4790K
Processor cooling: Corsair H110i (does it makes sense to replace standard
fan with eg. Noctua NF-F12?)
Mainboard: Asus MAXIMUS VII RANGER
RAM: 16GB Corsair Dominator 2x 8GB 2400Mhz
Graphics: EVGA GeForce GTX 780 Ti SC ACX
OS HDD: Crucial SSD MX100 512GB
Power supply: Corsair AX760i
Therefore, I have 3 questions:
- do you consider the above setup a good choice for the next 3 years - in
terms of selected parts (in relation to the expected features)? Maybe there
are better alternatives within the budget?
- what case should I choose that is the most rigid and as small as possible?
- does it make sense (in terms of noise reduction) to use water cooling for
GPU instead of stock ACX?
I'd be grateful for your advice
Peter
* For discussion purposes, please assume that main storage (HDDs)
irrelevant.
gaming
Peter
irrelevant.
