- Jul 30, 2013
just a thought but what about this case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811345030
it can hold a 200mm/230mm fan in the front and obviously huge fan=more airflow but at a lower rpm thus lower noise. only downside i see is the cable management but thats an easy fix with a bit of creativity and yes you can fit that 7970 in there as well as a 212 evo. also with that motherboard to keep overclocking a valid possibility youll want to go with a z87 such as:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130706 on the lower end annd:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131977 on the upper.
idk if this is 100% required but a z87 is the absolute best ocing chipset at the moment.
