Building PC need help
mosuto
hello everyone, i would apritiate any help. i've been reading a lot last days in the inet and i have choosen some parts for building my own configuration PC. Only problem is that i am not sure the parts will fit and works good as one ^. i am not sure if the PSU i have choosen is good enuf and i am not sure what PC case i should get.
I will post the parts here and the specifications below. Thx in advance for teh help (and if u see i need some more parts please feel free to tell thx :))
MB: Intel DH67GD, P67, LGA1155, DDR3, 2xPCI-E, Lan1000, SB7.1, Sata, Raid
Processor: Intel Core I3-2100 3.1GHz 2 x 256KB L2 Cache 3MB L3 Cache LGA 1155 BOX
Grafic card: ASUS EAH5670/DI/1GD5, 1GB, 128-bit, DDR5, PCI-E
Hard drive: Hitachi - Deskstar 7K3000 1.5TB SATA 6Gb/s 64MB
RAM: Corsair KIT 4GB DDR3 1600MHz CMX4GX3M2A1600C7 XMS3
DVD CD RW: Sony AD-7243S Internal Black SATA
PSU: PSU Corsair CMPSU-600CXEU 600W
now the compleat info for this parts:
Model
Brand Intel
Model DH67GD
Supported CPU
CPU Socket Type LGA 1155
CPU Type Intel® Core™ i7, Intel® Core™ i5, Intel® Core™ i3, and Intel® Pentium processors
FSB
Supported CPU Technologies
Chipsets
North Bridge Intel® P67 Express Chipset
South Bridge
Memory
Number of Memory Slots 4 x DDR3
Memory Standard DDR3 +1600 / 1333 / 1066 MHz
Maximum Memory Supported 32GB
Dual Channel Supported Yes
ECC Supported
SLI-Ready Memory
Expansion Slots
AGP Slots
PCI Express x16 2 x PCI Express 2.0 x 16
PCI Express x4
PCI Express x1 3 x PCI Express 2.0 x 1
PCI-X Slots (64-bit 133MHz)
PCI Slots 2 X PCI
Other Slots
Storage Devices
Storage / Raid Two Serial ATA (SATA) 6.0 Gb/s interfaces through the Intel P67 Express
Chipset with Intel® Rapid Storage Technology RAID support (blue)
Four internal SATA 3.0 Gb/s interfaces through the Intel P67 Express Chipset with Intel Rapid Storage Technology RAID support (black)
One back panel eSATA port (red)
Onboard Video
Onboard Video Chipset
Onboard Audio
Audio Chipset Realtek ALC892 audio codec
Audio Channels 8-channel (7.1)
Onboard LAN
LAN Chipset Intel® 82579V Gigabit Ethernet Controller
Second Lan Chipset
Max LAN Speed 10/100/1000Mbps
Wireless LAN
Rear Panel Ports
PS/2
COM
LPT
Video Ports
USB 8 x USB 2.0 ports
2 x USB 3.0 ports
IEEE 1394 IEEE 1394a connector
Audio Ports 5 x Audio ports
SPDIF OUT S/PDIF out (optical)
RJ 45 1 x RJ-45
WiFi
eSATA 1 x eSATA connector
Other
Onboard USB
Onboard USB 3 x Front panel USB 2.0 headers
Onboard 1394
Onboard 1394 IEEE 1394a front panel header
Physical Spec
Form Factor ATX
Dimensions 30.48 cm x 24.38 cm
Features
Power Pin Main power connector (2 X 12), Processor core power connector (2 X 2)
Features
Packaging
Package Contents Box
Model
Brand Intel
Processors Type Desktop
Series Core i3
Model BX80623I32100
Technical Specification
Core Sandy Bridge
Multi-Core Dual-Core
Name Core I3-2100
Operating Frequency 3.1GHz
FSB
QPI
L1 Cache
L2 Cache 2 x 256KB
L3 Cache 3MB
Manufacturing Technology 32 nm
64 bit Support Yes
Hyper-Threading Support Yes
Virtualization Technology Support Yes
Multimedia Instruction MMX, SSE, SSE2, SSE3, SSE4.1, SSE4.2
Voltage
Cooling Device Heatsink and Fan included
Packing BOX
Manufacturer Warranty 3 year
ASUS EAH5670/DI/1GD5, 1GB, 128-bit, DDR5, PCI-E,
Model
Brand Asus
Model EAH5670/DI/1GD5
Interface
Interface PCI Express 16X
Chipset
Chipset Manufacturer ATI
GPU Radeon HD 5670
Core clock 775 MHz
Stream Processors / Pixel Pipelines
Memory
Memory Clock 4000 MHz
Memory Size 1GB
Memory Interface 128-bit
Memory Type DDR5
3D API
DirectX DirectX 11
OpenGL OpenGL 3.2
Ports
Video Port 1 x VGA / 1 x DVI / 1 x HDMI
TV-Out HDTV
VIVO No
General
Tuner No
RAMDAC 400 MHz
Max Resolution 2560 x 1600
SLI Supported Yes
Cooler Fan
System Requirements
Dual-Link DVI Supported Yes
HDCP Ready Yes
Features
Features
Packaging
Package Contents Software Bundled ASUS Utilities & Driver
Model / Модел
Brand / Марка Hitachi
Series / Серия Deskstar 7K3000
Serial Number / Сериен номер n/a
Performance / Характеристики
Interface / Интерфейс SATA 6GB/s
Capacity / Обем 1.5TB
Rotation Speed / Скорост на въртене 7200rpm
Cache / Буфер 64MB
Physical Specification / Физически параметри
Device Location / Тип устройство Internal - Вътрешен
Form Factor / Стандартен размер 3.5" - 8.89 cm/см
Model
Brand Corsair
Model CMX4GX3M2A1600C7
Type 240-Pin DDR3 SDRAM
Tech Spec
Capacity 4GB (2 x 2GB)
Speed DDR3 1600 (PC3 12800)
Cas Latency 7
Timing 7-8-7-20
Voltage 1.65V
Heat Spreader
Manufacturer Warranty Lifetime limited
Model
Brand Sony
Model AD-7243S
Type Internal
Performance
Cache 2MB
Physical Spec
Form Factor
Panel Color Black
Write Speed
BD-R
BD-RE
DVD+R 24X
DVD+RW 8X
DVD-R 24X
DVD-RW 6X
DVD-RAM 12X
CD-R 48X
CD-RW 32X
BD-R DL
BD-RE DL
DVD+R 9 12X
DVD-R DL 12X
Read Speed
Blu-ray DVD-ROM
DVD-ROM 16X
CD-ROM 48X
Configuration
Interface SATA
: 600W, 80+ efficiency, 12cm Fan
thats all. THx in advance
mostly gaming, but i can afford to give a lot $$$ for the newest stuff :S
Have a look at the rig in my signature and that should at least give you a good starting point.
What is your budget?
As for a case you can only get recommendations as its more or less a personal choice. I like the nzxt phantom for its looks but the haf x is a REALLY nice case. These are better for non watercooling. A water cooling setup you'd need a modding skill because there will have to fit a lot of rads into that.
THx for answears
my buget is 800$~
so if u can recomend something around this price i will apritiate it :)
For around $800, this is what I would do. Not very upgrade friendly, but pretty good for the price. If you can scrounge up $20 over your budget for a Hyper212+, you can OC this bad boy to 4.5GHz or more.
Looks fine, other then the fact that's a last-generation video card, and it isn't that powerful. Look for a GTX560 or a Radeon HD 6870/6950.
