- Jul 8, 2013
I guess this should go here since it has to do with psu cables
Anyway looking to buy some cable combs, amazon was completely useless as the pieces were extremely over priced.
Checked ebay and found this 50pc kit http://www.ebay.com/itm/2-85mm-Cabl...var=571883166588&_trksid=p2055119.m1438.l2649
and performance pc's http://www.performance-pcs.com/cablemod-cable-combs-4-28-slot-clear.html
Mine are silverstone sleeved extensions so I need 2.85mm combs.
Do I need more than 2 for each plug? (24 pin mobo, 8 pin cpu, 6 pin + 8 pin gpu)
Which one should I get?
