invictius
Disabled
- Oct 8, 2005
I'm just wondering, what's the largest drive a 360 can handle via USB? I mean, does it recognise over 127gb (since win 9x can't)?
I've detached my xbox hard drive, replaced it with a 512 memory card, as (tell me if you disagree) - hard drive=mechanical=more prone to failure. I don't have the faceplate to cover the sata port, is this a Bad Thing to have running?
One last thing, judging by the pics below, is my xbox ventilated enough?
wood is there so the unit is stable during disc reading:
one side is a bit jammed next to the pc case:
the unit is pushed 8 inches forward so I can reach the thing - the left (non-pc) side of the unit is 10 inches away from the tv stand (which isn't in the pic) and that pipe thing is blowing hot air out of my psu, so it doesn't get sucked in by the case fan at the rear:
Thanks in advance for your tips. Now I'm temporarily (crossed fingers) without cable, I can put the thing in a well-ventilated space, but the "ring" is a bit annoying (e.g it catches your eye) when playing it on the projector in that position, so I'd really rather only move it if someone says "OMG it's a wonder that xbox isn't dead yet!!!11". Thanks in advance for your opinions!
