Im fairly new to overclocking, and want to quickly oc my system and was hoping someone here could post a safe oc setting for my system. Here is all the info I have collected:
CPU-Z version 1.44.1
Processors Map
Number of processors 1
Number of threads 2
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Athlon 64 X2 4200+
Codename Brisbane
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
Package Socket AM2 (940)
CPUID F.B.2
Extended CPUID F.6B
Brand ID 4
Core Stepping BH-G2
Technology 65 nm
Core Speed 2256.7 MHz (11.0 x 205.2 MHz)
HT Link speed 1025.8 MHz
Stock frequency 2200 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 11.0x
max VID 1.300 V
Features XD, VT
K8 Thermal sensor yes
K8 Revision ID 6.0
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Chipset
Northbridge NVIDIA MCP61 rev. A3
Southbridge NVIDIA MCP61 rev. A2
Graphic Interface PCI-Express
PCI-E Link Width x8
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 322.4 MHz (CPU/7)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 15
Bank Cycle Time (tRC) 21
Command Rate 1T
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Transcend Information (7F4F000000000000)
Size 2048 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number JM667QLU-2G
Serial number 0007B58E
Manufacturing date Week 01/Year 08
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 200 266 333
CAS# 3.0 4.0 5.0
RAS# to CAS# delay 3 4 5
RAS# Precharge 3 4 5
TRAS 9 12 15
TRC 12 16 20
DIMM #2
General
Memory type DDR2
Size 2048 MBytes
Manufacturing date Week 02/Year 08
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 15
TRC 12 16 20
Monitoring
Mainboard Model M61SME-S2 (0x24B - 0x29C99C8)
Hardware monitor
ITE IT87 hardware monitor
Voltage sensor 0 1.26 Volts [0x4F] (CPU VCORE)
Voltage sensor 1 1.90 Volts [0x77] (VIN1)
Voltage sensor 2 3.34 Volts [0xD1] (+3.3V)
Voltage sensor 3 5.08 Volts [0xBD] (+5V)
Voltage sensor 4 12.10 Volts [0xBD] (+12V)
Voltage sensor 5 -12.86 Volts [0xC9] (-12V)
Voltage sensor 6 -0.38 Volts [0x6] (-5V)
Voltage sensor 7 5.00 Volts [0xBA] (+5V VCCH)
Voltage sensor 8 3.09 Volts [0xC1] (VBAT)
Temperature sensor 0 38°C (100°F) [0x26] (TMPIN0)
Temperature sensor 1 37°C (98°F) [0x25] (TMPIN1)
Temperature sensor 2 34°C (93°F) [0x22] (TMPIN2)
Fan sensor 0 1929 RPM [0x15E] (FANIN0)
Fan sensor 1 1170 RPM [0x241] (FANIN1)
Hardware monitor
AMD Athlon 64 X2 4200+ hardware monitor
Temperature sensor 0 14°C (56°F) [0xFA] (core #0)
Temperature sensor 1 18°C (63°F) [0x10A] (core #1)
Dump hardware monitor
Hardware monitor
Radeon X1650 Series hardware monitor
Temperature sensor 0 49°C (120°F) [0x31] (GPU Core)
HyperTransport Capability
Offset 44h
Revision 1.03
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 1000MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200MHz
Offset DCh
Interface type MSI Mapping
PCI Express Capability
Offset 80h
Device type Root Port of PCI-E Root Complex
Port 0
Version 1.0
Physical slot #0
Presence detect yes
Link width 8x (max 16x)
DMI
DMI BIOS
vendor Award Software International, Inc.
version F9b
date 01/22/2008
DMI System Information
manufacturer Gigabyte Technology Co., Ltd.
product M61SME-S2
version unknown
serial unknown
UUID 30303144-37444242-31414346-FFFFFFFF
DMI Baseboard
vendor Gigabyte Technology Co., Ltd.
model M61SME-S2
revision unknown
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer AMD
model AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
clock speed 2255.0MHz
FSB speed 205.0MHz
multiplier 11.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 1024MBytes
DMI Memory Module
designation A0
size 2048 MBytes (double bank)
DMI Memory Module
designation A1
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
designation Detected (external)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB (internal)
port type USB
connector Access Bus (USB)
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated yes
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 1024MBytes
max# of devices 2
DMI Memory Device
designation A0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
Software
Windows Version Microsoft Windows Vista (6.0) Home Premium Edition (Build 6000)
DirectX Version 10.0
Processors Map
Number of threads 2
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
Codename Brisbane
CPUID F.B.2
Extended CPUID F.6B
Brand ID 4
Core Stepping BH-G2
Technology 65 nm
FID/VID Control yes
max FID 11.0x
max VID 1.300 V
Features XD, VT
K8 Revision ID 6.0
Chipset
PCI-E Link Width x8
Memory Type DDR2
Channels Dual
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 1T
Memory SPD
DIMM #1
General
Memory type DDR2
Size 2048 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 15
TRC 12 16 20
DIMM #2
General
Memory type DDR2
Size 2048 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 15
TRC 12 16 20
Monitoring
Hardware monitor
Hardware monitor
Hardware monitor
Offset 44h
Revision 1.03
Offset DCh
Offset 80h
Port 0
Version 1.0
Physical slot #0
Presence detect yes
DMI
DMI BIOS
version F9b
date 01/22/2008
product M61SME-S2
version unknown
serial unknown
DMI Baseboard
model M61SME-S2
revision unknown
serial unknown
DMI Processor
manufacturer AMD
FSB speed 205.0MHz
multiplier 11.0x
DMI Memory Module
designation A0
DMI Memory Module
designation A1
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
connector DB-9 male
DMI Port Connector
connector DB-9 male
DMI Port Connector
DMI Port Connector
connector PS/2
DMI Port Connector
connector PS/2
connector PS/2
DMI Port Connector
port type USB
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated yes
usage System Memory
correction None
max# of devices 2
DMI Memory Device
designation A0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
Software
