- Apr 29, 2010
- Central FL
My trusty ASUS RT-N16 is starting to show it's age so I've been shopping around for a replacement but can't quite figure out which one to use. I've always used DD-WRT on my Linksys routers and currently run Tomato on the RT-N16 but from reading over the DD-WRT forums and various internet searches the support from both is spotty. It is all in the works but not what I would call finalized. DD-WRT has support for the newer ASUS and Linksys but it seems to break some things while fixing or adding others and needs constant updates. There also seems to be a better chance of bricking than there used to be. Tomato for the most part is not supported except for a couple people working the old builds for use on the newer generation of routers. Add all that to the fact that I just don't have the time to tinker that I used to, I would rather run something out of the box if possible. I don't really use most of the extras Tomato or DD-WRT add to the router, I mainly use their firmware for the reliability factor they bring so giving up features is ok. Does anyone use a newer AC router with stock firmware that can attest to the reliability of it? For example this RT-N16 has run problem free with almost no reboots for years up until recently. Can the new wireless routers do the same?
I realize "our standards" are dependent on each person's needs but I assume for the most part we all have the basic needs (reliability, security, etc) then look for the extras so I am looking for personal opinions here. Thanks!
