- Jun 24, 2006
- Christchurch, New Zealand
Download: http://sites.amd.com/us/game/downloads/Pages/downloads.aspx
Release Notes: http://support.amd.com/us/kbarticles/Pages/AMDCatalyst1012ReleaseNotes.aspx
"New Features:
Support for DivX on the AMD Radeon 6800 Series
With DivX® software installed on an AMD Radeon™ HD 6800 Series and later GPU and the DivX Accelerated™ solution, consumers can enjoy an improved DivX video playback experience by lowering CPU load, extending computer battery life on notebooks, reducing noise on home theater PCs and improving overall computer operation.
Grab the DivX Accelerated download from here (will be available Dec 15) http://go.divx.com/accelerated
Support for OpenGL 4.1
New features introduced in OpenGL 4.1
Full compatibility with OpenGL ES 2.0 APIs for easier porting between mobile and desktop platforms
The ability to query and load a binary for shader program objects to save re-compilation time
The capability to bind programs individually to programmable stages for programming flexibility
64-bit floating-point component vertex shader inputs for higher geometric precision
Multiple viewports for a rendering surface for increased rendering flexibility
New ARB extensions introduced with OpenGL 4.1
Linking OpenGL sync objects to OpenCL event objects for enhanced OpenCL interoperability
The ability to set stencil values in a fragment shader for enhanced rendering flexibility
Features to improve robustness, for example when running WebGL applications
Callback mechanisms to receive enhanced errors and warning messages
AMD Stream 2.3 SDK release
Performance improvements for AMD’s OpenCL toolset
Support UVD video hardware component through OpenCL driver (Windows 7 only)
Support for the Stream Profiler on Linux (command line version)
Support added for AMD Radeon HD 6800 Series and AMD Radeon HD 6900 Series
Support for FFT and BLAS-3 libraries
Stream Profiler enhancements (including timeline visualization)
Resolves a number of bug fixes from the Stream SDK 2.2 release"
"New Features:
