- Sep 1, 2003
- Toronto, Canada
Hi folks, I've been searching the web for a solution to the title but couldn't find one so I decided to run it by you.
Is there any way to make Windows 7 fonts larger without effecting the DPI settings which makes things look a bit blurry and fuzzy? Windows XP has simple and easy solution which works very well but that doesn't seem to exist in Windows 7 or does it? Any suggestions?
Thanks in advance,
_A
Thanks in advance,
_A
