AlexNorton
- Jun 22, 2020
Which One Is Better: Shark NV356E vs NV360 vs NV370?
In the current market, Shark is one of the most famous vacuum manufacturers. Although it has produced several different shark navigator lift away deluxe machines, the NV356E vs NV360 vs NV370 are noticeable products. They have similar features, but these models still different from some aspects. Let's check below:
❅❅❅ Related Article: Shark Navigator Lift Away Deluxe Nv360 upright vacuum
The Shark NV356E
The Shark NV356E is a navigator lift-away dlx vacuum cleaner, which allows you to take out the canister. This detached canister is used to clean hard-to-reach spaces or areas in high positions.
But, how to release the main canister and lift it away?
Simply press a small button.
With 13.7 pounds, you can easily control, use, and move this machine. Combining the lift-away mechanism and the lightweight feature brings the maximum convenience to clean any space and place around your house.
Can you see the Shark NV356E cleaner head at the bottom? This brushroll brings 2 outstanding features:
It can clean the carpet deeply. Not any lift-away vacuum cleaner has this function, but the Shark NV356E can efficiently perform this task. Besides, this machine is gentle enough to work well on a hard surface.
The Shark NV356E is a cheap and functional vacuum cleaner.
The Shark NV360
The Shark NV360 is an upright vacuum. It is similar to the Shark NV356E, but this model comes with some improvement.
The total weight of the shark navigator lift away deluxe NV360 is 12.5 pounds. But, if you need a more lightweight machine, you can lift-away the 7.5-pound canister to clean the difficult-to-reach areas.
What's more, please forget forcing your cleaner into the hard-to-swivel positions to fit through them. This machine features a Swivel Steering. It means that the vacuum cleaner will swivel the head around your pieces of furniture to move easier.
The cleaning ability of Shark NV360 is similar to the Shark NV356E. Here is the detailed information:
This vacuum cleaner is designed to clean both carpets and hard floors. Thus, no matter where you will use this machine, it can help you remove all dirt and dust.
Here is a lighter and more mobile vacuum cleaner.
The Shark NV370
Compared to other vacuum cleaners, the Shark NV370 has all of the outstanding features of the Shark NV356E and the Shark NV360 as follows:
- The swivel steering
- The lift-away mechanism
- The great cleaner head
- The excellent brushroll
Yes, this vacuum cleaner comes with some useful accessories: an 8-inch crevice tool for cleaning dirt and dust in small and tight areas, a pet brush for cleaning up pet hair, a dusting brush for removing the dust-caked onto some particular areas.
✠✠✠ Check Over: Shark Navigator Lift-Away Upright Vacuum Blue NV360 Reviews
In case you need a model with more functionality, the Shark NV370 should be your choice.
Among Shark NV356E vs NV360 vs NV370, the Shark NV356E has all essential features at a low price, and the Shark NV370 comes with more functionality at the highest price. However, I strongly recommend you pick up the shark navigator lift-away deluxe nv360 because it has enough features and functions to perform most cleaning tasks at a reasonable price.
