I just use Ccleaner. Does the job nicely and is able to securly overwrite the stuff it cleans up.
Here's the site
Silver_Pharaoh
I use none. Often, they are more trouble than they are worth. Many threads on this subject in fact at this site.
This.
Be selective of what programs you install, and where you install them. Routinely go through your 'Add/Remove Programs' list and remove things that you haven't used and don't anticipate using. I have a habit of formatting at least twice a year just for my own peace of mind.
By formatting you mean wiping your hard drive and doing a clean OS install right?
I've used CCleaner for 8 years on systems that from very old to fairly new both at work and at home. Never had any issues. Recommended it to coworkers, families and friends. Again, never any issues.
Partition SSD drive. Install OS on relatively small partition. Do not keep any personal files on OS partition the Drive Image the OS partition to another larger drive. This allows you to nuke the OS partition once a month, install Patch Tuesday updates and make any changes to original install, then Drive Image again.
If Windows Update, driver update, virus, bad programming mess up your Windows, you simply reimage your OS partition in less time than it takes for you to go on a short bathroom break. Because of doing that, I've had a feeling of a brand new install at least once a month for more than ten years now.
My favorite time-saver is when something difficult to detect causes my system to hick up. I look at the txt file of monthly changes I made to my master image and deduce the culprit quickly because I keep a few drive image files for later, in case something like that happens - then I can reimage back to the state te system was before that change was made and simply look at the txt file to implement the other changes I made without installing whatever caused the problem.
This was true more than ten years ago and it is true today: Nothing makes my PC go faster then when I restore from a backup made just after I first installed the OS the way I want it to be...
CCleaner just works!
My Windows partition on SSD is 35 GB.
If you install Windows 7 or 8 on one and Windows XP on another, then buy this
http://www.terabyteunlimited.com/image-for-windows.htm
then image one OS from the other onto another physical drive.
then my Windows 8 image stored takes up less than 14 GB, my Windows XP image takes up less than 8 GB.
I use E:\Program Files directory to install large applications into, not C:\Program Files - this makes imaging/reimaging of the main OS partition faster.
