Removal Instructions (From Hardware)
1. Arctic Silver thermal compound can easily be removed from hardware using the proper cleaners and tools. For general clean-up, a cloth or paper towel will work well. Intricate cleaning can be accomplished with Q-tip swabs. An old toothbrush can often get the compound out of crevices that other tools cannot reach.
The recommended cleaners are:
CPU Core:
Use high-purity isopropyl alcohol or acetone and a bit of careful rubbing.
Do not use nail polish remover as it contains fragrance oils and other contaminants.
(If you use acetone, do a final cleaning with isopropyl alcohol.)
Heatsink:
Use xylene based products (Goof Off, some carburetor cleaners and many brake cleaners.), mineral spiritsm or high-purity isopropyl alcohol.
Remember:
Once you have applied a thermal grease or melted a thermal pad onto a heatsink, it is impossible to remove all of the grease or pad from the microscopic valleys in the heatsink using standard cleaning chemicals and paper or fabric towels. Any subsequent thermal material will be applied over the remnants of the original material.
Never use any oil or petroleum based cleaners (WD-40, citrus oil based grease removers and many automotive degreasers) on the base of a heatsink. The oil, which is engineered to not evaporate, will fill in the microscopic valleys in the metal and significantly reduce the effectiveness of any subsequently applied thermal compound.
CPU Ceramic:
Use any of the following cleaners.
Any dish detergent. (Dawn, Lux, Palmolive, Etc.)
Do not use soap for an automatic dishwasher to clean a CPU.
WD-40, citrus based cleaners.
Xylene based products. (Goof Off, some carburetor cleaners and many brake cleaners.)
Mineral spirits. (Be careful to keep the mineral spirits away from the core.)
Once the majority of the compound has been removed from the ceramic, small patches remaining on the ceramic can be 'erased' with a soft eraser.
2. If you use any of the suggested products to remove Arctic Silver thermal compound from the CPU ceramic or heatsink base, always do a final cleaning with isopropyl alcohol to remove any residue from the cleaner.
Yup, it usually has a bunch of crap like perfumes in it that make it less than ideal. AFAIK, pure acetone is good though.itshondo said:I think nail polish remover contains some oils, if not other things. It's not 100% acetone.
TIS said:i use goof off - works better then iso...
benbaked said:one time i didn't have any alcohol so i used cool mint listerine. it took a little longer but it worked.
Or that if you don't give a crap about your processor.fel said:I just spit on it!
Hrrrrggggggrgrgrggg! SPIT!
It works!
Then cleanit whit a kleenex.
Good luck.
