compatible coin battery ?
pongo
hi, i am looking for compatiable coin battery chargable or non chargable of 3.7 V 520 mAh 2.00 Wh .. which one i can find easily ? any equivalent to the volts would also help.... in 1 or 2 piece can also work...
please suggest...
thanks !
Is there a model number on the existing battery or do you not have it. Most hardware stores can match it with an equivalent product if you know the model number.
