I'm going to wire and solder 5 super bright LEDs in series with a 100 ohm resistor, and i'm going to use the +12v on a molex connector. My question is... What if I plug that molex connector in a molex to 3pin splitter to my fan controller, will it work?
LEDs, resistors and the molex connector
Some black and yellow wires
The 4 pin molex to 3 pin splitter
Here's a drawing on how the wires are connected in the splitter:
My entire LED setup
That's the comparison between a standard connection on a male molex and the splitter i'll be using. If i plug the yellow and black wires at the same place i would plug them on a standard molex, the 12v would go in the red wire on the 3pin fan...is it the 5v? My question is....where do I plug the yellow and black wires so that the 12v and ground will be at the right place in the fan controller?
My entire LED setup
