Beginner do it yourself computer builders typically throw some big bucks at the CPU and motherboard and maybe a video card but skimp on things like the PSU, the CPU cooler and the case. Experienced PC enthusiast do it yourselfers know that a quality case with good ventilation, a quality low ripple PSU and an efficient CPU cooler are foundational components to good overclocking and reliable computing. You wouldn't want to build an expensive house on a shakey foundation, would you?
You're well on your way crafoo. I'm fairly new to this forum but I'm very impress by the knowledge and quality of advice here. Friendly folks too.
The other nice thing about a good PSU, case and cooler is that it's transferable to the next system. With some limitations of course. I've done this on numerous occasion and makes the cost of my next system a little more affordable. Typically fitting a standard ATX PSU into a case is not a problem. CPU cooler and GPU, due to size, can sometimes be problematic. That's why getting a good case is also as important though it not need be expensive. For example I got a Coolermaster HAF 922 that will accommodate anything I throw into it for the next foreseeable future. I got it on sale for $89 Cdn. PSU that comes with cases are typically junk. The one no name junk that I got with a case is running 1 120mm fan in my wine cooler that's been converted into a cigar humidor. That PSU will never power any CPU.
It is probably fair to say that with a given brand or line of PSU the higher the wattage the better. The problem is, however, that off brand PSU makers tend to greatly exaggerate their numbers and also rate the wattage by applying it to "peak power" rather than sustained power. They also tend to produce PSUs that are not eco efficient and do not produce "clean power", that is signals with low ripple or low electrical background "noise", the latter being important to high overclocks.
As you say the unbranded variants do seem to make big claims to try and appear to be as good as the more expensive stuff but I guess the old saying "you get what you pay for" rings true yet again Just wish I'd bought a good one in the first place
I agree with n0t beating yourself up. They sell the same line of stuff here in the Usa. If you follow that link below, you will see users say the case/ps is top tier and then those that say it is purely shett. So when I see that...I have a good idea that I will only have about a 50% chance of success. And generally that is an accurate rate when I look on these and other forums and has been that way for 14 years I have been fooling with these ones and zeros handlers.
If I bought that $50 dollar case I linked and found out the power supply was not good...well that is the cheapest form of error to correct.
HEC 6C28BBX585 Black Steel ATX Mid Tower Computer Case 585W Power Supply
Touch that FEEDBACK button. I went thru the first 10 or 12 'user' type reviews. That case power supply is very similar to the class of deal you purchased. 585 watts. Wowee.
Some Feedback:
Pros: Decent case, big enough to fit all of my components.
Cons: Hooked up mobo to the PSU along with the HDD and disc drive.
Wouldn't turn on. Reworked wires... Wouldn't turn on.
Got my trusty electrical current detector and of course, the PSU wouldn't transmit anything.
Pros: The case was ok, I had to remove the air duct because of the cpu cooler was too big.
The power supply in this case is only marginal I had to replace the one that came with it because of high pitch noise when the machine was on and when turned off. The ps was only two years old.
Cons: Weak power supply, and case shows dirt, dust and finger prints
Pros: It looks good
Cons: Power supply was dead on two separate cases. I returned the first one because it arrived dead. The replacement that was shipped to me took less than 24 hours to die. Do not waste your money.
And you need to remember one thing...we know how critical good power is to a system. We have really majored on that in your situation. You cannot get it to run well enough to even capture and post the pics of ram and stuff so we could see what in the world is going on with ram and stuff. We hope the P/S gets you some relief but don't panic if the P/S is not the whole problem. We needed to start at the start.
We will all mostly be here after the power supply switch out and then to tidy up the stuffz that needs the tidying. Luck man. RGone...ster.
I'm sorry but the multi posting is greatly annoying.
Please just edit your posts if no one has replied.
Have you checked the BIOS version of the board? I'm just weary about that board running an X6, especially with an outdated bios.
Having said that, it might be a video issue since anytime I've ran into problems with the screen looking like that, it was video related. Since the board has onboard video, I say just return the board, it's likely defective.
That's all I've got as I rarely deal with defective hardware/build issues, sorry.
