Wanting to stretch out the life of my phenom ii x4 980 by overclocking a bit I bought the cooler master seidon120M RL-S12M-24PK-R1 water cooling setup for my PC. Before this on the stock clocks and stock AMD heatsink I would never go over 50-55c playing games or about 60 c during a load test (using AMD overdrive for that) and idle around 45c.
I installed the water cooler today and now it idles at around 45-50c! During load tests about 2 minutes in its already at 58+c and I shut it off. A quick session of planetside 2 resulted in temps approching 60C
I just pulled it back off and looked at the thermal paste, it looked a bit thin so I applied some more with the credit card method, still no dice the temps are the same. I have the fan hooked up to the stock fan plug (set at 100 percent) and the pump hooked up directly to the power supply using a converter plug.
Could there be something wrong with the pump etc, or is this simply not enough cooler for my CPU? Unfortunately I purchased this before finding out this forum existed. After reading the FYI section for noobs it seems like I need a 240 for it to even work?
My setup:
AMD phenom ii x4 980 black
Asus M3A78 pro
8 GB ram
BTW, I noticed that after a load test getting up to 60c it took FOREVER to come down to temp, the air coming out of the radiator was still ice cool, and the radiator itself was not hot. Seems like the water is not getting pumped correctly?
Thanks for any help in advance.
My setup:
Asus M3A78 pro
8 GB ram
