Hello,
I attempted my first water cooling build. However, on stress tests it hits 100 celcius within 10 seconds on all cores. It idles around 27. I don't even feel heat coming out of the radiators. My cpu isn't overclocked. I double checked the screws on the backplate and reapplied thermal paste using a pea sized drop. Low idle temps so I think the contact to the waterblock is fine. It just heats up so fast. No kinks or leaks. I ran the pump 12 hours, so most of the bubbles are gone. I have an anti-vortex foam in the reservoir.
Core i7 4790k
EK supremacy EVO cpu block
EK d5 pump/res combo (newest) with pwm control on sys fan.
1x 280mm rad, 1x 120mm rad DI water
Any thoughts?
I've used multiple stress tests including d9 , heavy and ASUS
Core i7 4790k
Any thoughts?
