Intel Core2Duo E8400 Wolfdale overclocked to 3.8GHz
* Passed: 8 hours of each of the following with no problems.
o Prime95 Blend
o Orthos Blend
o Memtest
* Passed:
o Also tested with 3DMark03
o Also tested with 3DMark06
* Cooler: ZALMAN CNPS9500 AT (Large fan and heatsync)
* 1x Winner of Customer Choice Award (Newegg)
ABIT IP35E Motherboard
* 7.1 Channel Realtek HDMI Audio
* Ethernet 10/100/1000 mbps included
* 4 USB Slots
* Keyboard/Mouse Pin connectors
EVGA 8800GTS 512MB
* New 65nm GPU clocked at 670MHz
* 128 Stream Processors at 1.67GHz
* 512MB of DDR3 at 1.94GHz
* Second Generation PureVideo HD
* PCI Express 2.0 Ready
CORSAIR HX520W PSU
* Provides enough power for stock and increased voltages
4GB (2x2GB) CORSAIR PC6400 C5 RAM (Adapted to CPU Overclock) 5-5-5-18
* Currently running at 844 MHz 1.95V
Samsung SH-S203N DVD/CD Burner
* LightScribe support
* WriteMaster Technology
* Power Speed Technology for 20X Writing
* Powerful overspeed support
* Low noise and vibration control system for high speed
* Optimized algorithm for fastest speed
* Write Speeds
o DVD+R 20X
o DVD+RW 8X
o DVD-R 20X
o DVD-RW 6X
o CD-R 48X
o CD-RW 32X
o DVD+R DL 16X
o DVD-R DL 12X
o DVD-RAM 12X
* READ Speed
o DVD-ROM 16X
o CD-ROM 48X
500GB Seagate Barracuda 7200 RPM 16MB Cache
Antec P180B Advanced Case
* Upper and lower chamber structure: The power supply resides in a separate chamber to isolate heat from the system and lower system noise
* Three-layer side panels and front door (aluminum, plastic, aluminum) dampen system noise, making this one of the quietest cases available
* Cooling System:
o 1 rear (standard) 120mm TriCool Fan with 3-speed switch control
o 1 top (standard) 120mm TriCool Fan
o 1 lower chamber (standard) 120mm TriCool Fan
* Upper drive cage can be used as a duct to provide fresh air to graphics cards
* External fan control on the rear panel for the top and rear fans in the upper chamber
* Maximum expandability with 11 Drive Bays
* Double hinge front door designed to open up to 270º
* 7 Expansion Slots
* Front Ports
o 2 x USB 2.0
o 1 x IEEE 1394 (FireWire®, i.Link®)
o Audio In and Out
* Cable organizers behind motherboard tray minimize cable clutter
* Material: 0.8mm cold rolled steel for durability through the majority of chassis, 1.0mm cold rolled steel around the 4x HDD area
* Silicone grommets in the hard drive cages absorb vibrations and reduce noise
* Built in washable air-filter
* Minor scratches to right panel from opening packaging
o Prime95 Blend
o Orthos Blend
o Memtest
* Passed:
* 4 USB Slots
EVGA 8800GTS 512MB
CORSAIR HX520W PSU
* Write Speeds
o DVD+R 20X
o DVD+RW 8X
o DVD-R 20X
o DVD-RW 6X
o CD-R 48X
o CD-RW 32X
o DVD+R DL 16X
o DVD-R DL 12X
o DVD-RAM 12X
* READ Speed
o DVD-ROM 16X
o CD-ROM 48X
* Cooling System:
* 7 Expansion Slots
* Front Ports
o 2 x USB 2.0
o Audio In and Out
