- Jun 27, 2002
Hi all... I got my oem 64mb radeon 8500 from newegg yesterday and put it in my system. After playing around with 3dmark a bit I decided to try out tweak3d... so I put my ram and gpu both up to 290 and ran 3dmark some more. Then I set my agp aperature to 64 megs from 128 to see if it did anything... a little drop in score, so I decided to try out 256, and that's when my problems started. Now windows seems to run much slower, like where I used to click on something and it'd flash open, it lags. I ran 3dmark and was appalled when I got a consistent 4-5 fps on the low detail car chase test... Alrighty I figured, just turn the agp back to 128 and I'll be on my merry way. Unfortunately that didn't change a thing, and I'm still having all of the problems listed above even though my system set just how it was when it ran great. I even set my vid card back to default and disabled tweak3d for the time being. I've tried to run games as well, in hopes that for some reason 3dmark was screwed up... same thing, horrible frame rates. Right now I'm thinking that my vid ram is fried, because whenever it runs 3dmark, the harddrive is constantly churning... I mean the light is constantly lit, like it's having to run the test right from the harddrive, and the constant frame rates seem to make it seem that it's being limited by my harddrive speed. I've counted out the possibility of my system memory, chip, or harddrive because I ran sandra on each and got the same score as usual. I'm just hoping that someone could give me some more ideas, or confirm my theory that I have no video memory... please help! My system specs are as follows
Epox 8k3a
XP-1800 @ 1620ish (9.5x169)
256samsung pc2700
and obviously, radeon 8500 64meg
thanks, I hope I can get this squared away... I'm hoping it's some setting I'm not thinking of
"Mighty" Joe
Epox 8k3a
256samsung pc2700
"Mighty" Joe
