- Feb 26, 2003
So i am daring to venture into a new world!
Creating scripts to run to install things.
I wanted to start to read up on how i can create my own scripts post-installation to install packages into CentOS and do configurations.
i have a document i wrote, but i would love to turn it into a single .sh file i can run and poof! server is set up and done!!
This is my test environment guide i wrote for setting up a test CentOS 6.* / PHP-FPM / MySQL and NGINX for word press sites.
I know most commands i can just enter in one after the other, the hard part seems to be when i want to modify files with nano and such or allowing user input where needed like the DB user creation...
Any direction the pro's can lead me in?
Code:
NGINX WebServer set up
## Install Remi Dependency on CentOS 6 64BIT##
rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/epel-release-6-8.noarch.rpm
rpm -Uvh http://rpms.famillecollet.com/enterprise/remi-release-6.rpm
## Install Nano for editing files
yum --enablerepo=remi,remi-test install nano -y
## Disable SELinux
nano /etc/selinux/config
## Change:
SELINUX=enforcing
to
SELINUX=disabled
## Turn off IPTables
chkconfig iptables off
## Reboot system to let SELinux changes take affect
reboot
## Update centos
yum --enablerepo=remi,remi-test update -y
## Add nginx official centos repository
nano /etc/yum.repos.d/nginx.repo
## Paste
[nginx]
name=nginx repo
baseurl=http://nginx.org/packages/centos/$releasever/$basearch/
gpgcheck=0
enabled=1
## Install nginx and php, mysql and other modules
yum --enablerepo=remi,remi-test install curl nginx php-cli php php-fpm php-common php-pear php-soap php-pdo php-mysql php-pgsql php-gd php-mbstring php-mcrypt php-xml gcc gcc-c++ spawn-fcgi wget mysql mysql-devel php-devel net-snmp net-snmp-utils ntp -y
# Start nginx on system start
chkconfig --add nginx
chkconfig --level 35 nginx on
## Start php-fpm on system start
chkconfig --add php-fpm
chkconfig --levels 235 php-fpm on
##Start mysqld on system start
chkconfig --add mysqld
chkconfig --level 345 mysqld on
#Start ntp on system start
chkconfig ntpd on
#Syncronize ntpd
ntpdate pool.ntp.org
#Turn on ntpd
service ntpd start
## Start nginx
service nginx start
##Start php-fpm
service php-fpm start
##Start mysql
service mysqld start
## Issue the following commands to create virtual hosting directories:
mkdir /etc/nginx/sites-available
mkdir /etc/nginx/sites-enabled
## Configure Nginx config file to add your sites
nano /etc/nginx/nginx.conf
## Add the following lines to your /etc/nginx/nginx.conf file, immediately after the line for “include /etc/nginx/conf.d/*.conf”:
include /etc/nginx/sites-enabled/*;
## Create virtual directory for your website(s), replace 'www.example.com' with your sites name
mkdir -p /srv/www/www.example.com/public_html
mkdir /srv/www/www.example.com/logs
chown -R nginx:nginx /srv/www/www.example.com
## Create virtual host file for your site, replace 'www.example.com' with your sites name
nano /etc/nginx/sites-available/www.example.com
## paste and edit, replace 'www.example.com' with your sites name
server {
listen 80;
server_name www.example.com;
access_log /srv/www/www.example.com/logs/access.log;
error_log /srv/www/www.example.com/logs/error.log;
root /srv/www/www.example.com/public_html;
if ($http_host != "www.example.com") {
rewrite ^ http://www.example.com$request_uri permanent;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# Deny all attempts to access hidden files such as .htaccess, .htpasswd, .DS_Store (Mac).
location ~ /\. {
deny all;
access_log off;
log_not_found off;
location / {
try_files $uri $uri/ /index.php?$args;
location ~ \.php$ {
include /etc/nginx/fastcgi_params;
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
#fastcgi_param SCRIPT_FILENAME /srv/www/www.example.com/public_html$fastcgi_script_name;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
## Create phpinfo file to verify PHP is working, replace 'www.example.com' with your sites name
nano /srv/www/www.example.com/public_html/test.php
##Paste in file
<?php echo phpinfo(); ?>
## Goto the enabled sites folder
cd /etc/nginx/sites-enabled/
## Create a symlink to enable the site
ln -s /etc/nginx/sites-available/www.example.com
## Restart nginx
service nginx restart
## Place an entry in your computers host file if needed to point your URL to your server for testing
##MySQL User Configuration:
mysql_secure_installation
grant all privileges on dbname.* to 'example'@'%' identified by 'example' with grant options;
## Configure SNMP
echo rocommunity public > /etc/snmp/snmpd.conf
##Restart snmp
service snmpd restart
#Run snmp on boot
chkconfig snmpd on
##Test SNMP
snmpwalk -v 1 -c public -O e 127.0.0.1
