- Nov 12, 2002
- Rootstown, OH
I had some options like read ahead and write back cache not available in raidxpert, so I had to dig up an answer. It wasn't that easy to find, so hopefully this will help others.
The bios that got it working for me was bios 1102 with a modified option rom. You can download it from the link in this post:
http://rog.asus.com/forum/showthrea...ut!-Version-1102&p=63332&viewfull=1#post63332
Once I flashed that bios, I then had all options available to configure my raid, and with read ahead/write back cache enabled the speeds are MUCH faster for my benchmarks.
Hope it helps.
Further info, posted in thread below:
Hope it helps.
Hello,
I wanted to point out that in Raidxpert you can, despite of MB brand, enable write back.
To achieve this:
Go into "physical drive view" and activate "write cache" - this is actually WRITE BACK
CACHE. If left disabled, the drive(s) will use "write through cache" as default.
Also it is important that when creating an array in the raid ROM "bios", you choose the option: write back or write through cache. After creating an array it can´t be changed at the ROM "bios" level.
BUT: Raidxpert allows to override this by the above explained manner.
This thread is a bit older, but I responded to this, since there are over 10K posts about this specific question in the internet and maybe the one or the other will/may can find this information helpful.
