- Oct 31, 2010
- Calabasas CA
I am attempting to cool my parents Home Theater Cabinet, as it can get up to 50c+ with normal use, and sometimes when everything is running gets even hotter as it does not have any ventilation at all. They close the cabinet as the dog and people run into it and it has broken before. (has already damaged some things and had to be replaced) this is relevant >
Anyhow, what I plan to to is cut a hole in the back (and/or side?) for a 120mm or 200mm fan. I'm on the wall here, what should I do? Should I go for 2 fans, one on the tv side to intake and one on the back for exhaust? and where? The tv is a new flat screen and puts out barely any heat. I have never really done any custom cooling jobs, so I'm completely lost here. Oh and fyi, I was not the one who did the wiring job, although they will let me mod it as much as I want.
This is whats on my list so far:
Sunbeam PL-RS-PCI Rheosmart PCI 20W Fan Controller
Item #: N82E16811995073
nMEDIAPC HTPC 1080iP Typical 60W, Maxiaum 85W Mini ITX DC to ATX Integrated Power Module with DC Adaptor
Item #: N82E16817129006
COOLER MASTER Megaflow 200 R4-LUS-07AR-GP 200mm Red LED Case Fan
or
Scythe SY1225SL12L 120mm "Slipstream" Case Fan
or
