- Aug 20, 2002
- Brooklyn, NY
Ouch! Well, I've seen them listed for 180 bucks on other sites.
I've started poking at this idea again too. I think I'll try it eventually, but yeah, if all you want to do is make one DDC top, it would be a bit pricey.voigts said:I had looked into doing that exact thing. It looked to me that it was going to be kind of costly to do,
What kind of comparison are you looking for?and also I could never get a good answer as to how resin compares to cast acrylic.
Obviously it means you have to modify your mold, but I don't think it would be overly complicated. I've been thinking the outlet channel mold should be a separate piece, and the little seam in Laing's top at the exit from the chamber makes me think that they probably do it that way. If you pull the mold out the same way the water goes, it shouldn't matter that the bore gets wider. But if you want to do it the other way, you could put an insert down the center of the bore that you could remove, leaving just a floppy sleeve to pull out through the chamber. It might be a good idea to use a rigid insert in the outlet channel anyway, just to to avoid droop.Also, if you look at the original top vs what you have to do to make it work 1/2" inlet and outlet barbs, it complicates the idea of casting as the exit channel has to widen out to accommodate the 1/2" barbs, whereas with the stock top the exit is a straight tube.
True. You could even leave the inlet at 3/8" if you wanted. The main performance boost comes from removing the inlet elbow. But as long as your at it...SolidxSnake said:You don't even need to change the outlet to 1/2", you can leave it 3/8" and have a 1/2" barb slip over it.
SolidxSnake said:You don't even need to change the outlet to 1/2", you can leave it 3/8" and have a 1/2" barb slip over it. It will kill some flow, but there will be less of a pressure drop. That was how I got my DDC. The top barb ripped off, so I had to redo the inlet, but the outlet was just the flare and stem (everything but the threads) of a 1/2" barb slipped over the stock 3/8" barb and epoxied on.
Careful, if you live in the US and someone gets it on video you will be looking at a $BIGMONEY fine if you are not CFC certified.Otter said:Ah. I was going to ghetto that. Something like an old steel mixing bowl or flower pot with a valve on it sitting upside-down on flat surface with a rubber mat for a gasket, maybe, plus a vacuum pump from ebay. If I replace my fridge before I get around to casting DDC tops, I'll probably use the motor from it. I once used a fridge motor I borrowed from a friend of a friend to pump down my car's AC, and it worked great.
voigts said:You can do that, but once you epoxy the 1/2" over the 3/8", your warranty is history.
Otter: The cost issue that I found in the idea of casting out of resin is that is would require a pressure chamber in order not to have air bubbles in the resin. And the cost of the pressure chamber was like $250 if I remember right.
voigts said:Also, if you look at the original top vs what you have to do to make it work 1/2" inlet and outlet barbs, it complicates the idea of casting as the exit channel has to widen out to accommodate the 1/2" barbs, whereas with the stock top the exit is a straight tube.
Back then, there was no such thing as CFC certification and it was perfectly legal to work on your own AC in the driveway.SiGfever said:Careful, if you live in the US and someone gets it on video you will be looking at a $BIGMONEY fine if you are not CFC certified.
Plus you can make that person a quick $10K.
SiGfever said:I use the Alphacool top and my DDC-2TPMP recently died, it started stalling until you tapped on it. I sent it back to DD and they replaced the pump. My old one was an 03/06 manufacture and the new one is a 01/07.
I know mine was not overheating as I had heat sinks on the bottom of it with a 120mm Yate blowing on them. Every time that I checked it was only barely warm.
lol tbh i do have to knock it pretty hard to get the impeller moving.otherwise it just half turns stops,half turns stops.i just hope the next pump is problem free...Maviryk said:Wow, if all else fails, whack it with a hammer.
I whacked my pump with a hammer and it started right up. I guess it just needed a little tough love.
voigts said:I would just rather add on a top with 1/2" outlets than mod the stock top so that I could return it if need be. But the idea of epoxying 1/2" fittings over the 3/8" ones isn't a bad idea.
I just worked today on two more DDC tops as I am about to tear into my setup and upgrade. I'm switching pumps back down to a DDC, so I figured I would go ahead and make a new top while I am at it. I wanted to make a top that is as close to the original as possible in the chamber design. My current top that I made is OK, but the new ones I just made have really turned out sweet. I've got the epoxy curing right now. I'll post a thread on it here shortly.
I measured and actually scanned the original top and printed out a template so that I could mimic the original top's impeller chamber very closely. I figure that if I have the chamber just like the original, it should minimize any issues.
Maviryk said:Do you have a 3d Digitizer?
I've got access to an Atos II white light scanner if you want 3d comparisons.
