I need to know what RAM settings should i use - look at my sig.
What is better? To use the default 1600 MHz rate with C9 timings or to use the lowered 800 MHz rate with C6 timings?
I have lowered my Corsair XMS3 RAM to 800 MHz in order to gain the lowest possible timings The FSB ratio is 1/2, so i don't really loose anything do i?
How would you do?
How would you do?
