- Jul 20, 2002
I have 2x16GiB of F4-4266C17D-32GVKB G-skill Ripjaws V installed on my daisy-chain topology Asrock z390 Taichi along with a 9700k. Getting anywhere near 4100Mhz. has been problematic so I was thinking maybe if I could provide additional cooling with say, six CUI or Delta 40x10mm fans attached to both DIMM's or 3 in-between both DIMM's (I have 4 DIMM slots, even though only 2 are being used ATM) I could add more V-DIMM and maybe get to the rated XMP speed of the RAM (4266 MT/s) or higher by adding more V-DIMM (I'm at 1.43V V-DIMM set in BIOS right now and 0.72V DRAM Vtt). If I can't get a higher operating frequency I'm hoping higher V-DIMM might enable me to tighten timings.
Right now, if I run Prime95 large FFT's with AVX the hottest DIMM can get up to 41°C.
