- Jan 10, 2012
this rig is sucking dog unstuffings through a 2x4, and that's some big time sucking!!!!
here's the issue, I am having a screen freeze every time I load a gpu, game, bench, whatever I load the gpu with
it's not the whole screen, only above the taskbar black screens, I can still see the task bar and can click stuff on the task bar but if it has to display above it I can either not see it or it does not work, eg; I invoke task manager, select the bench process, select end process, the end process dialog opens because it shows in the taskbar but it is hidden behind the black screen and the task manager is still on top.
click start button, menu appears, select shut down, it just sits open on top of the black screen, press window button, select shut down and it shuts right down.
asrock extreme 9, have swapped in my other board and processor, no effect.
cpu, 4790K, swapped it with the other motherboard.
gpu's I have swapped in and no effect.
asus 980ti in sli, both cards in single.
970's in sli and in single,
770 4 gig cards, in sli and single.
760 2 gig cards in sli and single
760 4 gig cards in sli and in single
280x cards in xfire and single
my ever trusty 7850
my never, ever going to get rid of 5450.
many many video drivers, I use ddu in safe mode.
2 new and three known good psu's 850 watt and above, good quality psu's.
2 fresh installs of win 7.
2 known good and 2 new ssd'd
all new sata cables
all psu cables that came with each psu.
any ideas before I throw all this stuff and/or myself into the wood chipper??????
my ever trusty 7850
all new sata cables
