Dependency hell
Shelnutt2
Overclockers Team Content Editor
/home/
Yep I've done it, I fell into the pit.
I tried to install a .deb (converted from rpm via alien),
Code:
K-Server:/home/shelnutt/Downloads# dpkg -i gravetat_0.9.1-2_i386.deb
(Reading database ... 290670 files and directories currently installed.)
Preparing to replace gravetat 0.9.1-2 (using gravetat_0.9.1-2_i386.deb) ...
Unpacking replacement gravetat ...
/var/lib/dpkg/info/gravetat.postrm: line 4: fg: no job control
dpkg: warning - old post-removal script returned error exit status 1
dpkg - trying script from the new package instead ...
/var/lib/dpkg/tmp.ci/postrm: line 4: fg: no job control
dpkg: error processing gravetat_0.9.1-2_i386.deb (--install):
 subprocess new post-removal script returned error exit status 1
dpkg: error while cleaning up:
 subprocess post-removal script returned error exit status 1
Errors were encountered while processing:
I then tried to convert to a .deb without scripts and then install it but I got this:
Code:
 there is no script in the new version of the package - giving up
So now anytime I try to use apt-get I receive:
Code:
K-Server:/home/shelnutt/Downloads# apt-get install -f
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
  module-assistant kbuild python-utidylib libx264-66 libtidy-0.99-0
  python-feedparser libphysfs-1.0-0 python-chardet
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
  gravetat
0 upgraded, 0 newly installed, 1 to remove and 4 not upgraded.
1 not fully installed or removed.
After this operation, 438kB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 290659 files and directories currently installed.)
Removing gravetat ...
dpkg: error processing gravetat (--remove):
 gravetat
E: Sub-process /usr/bin/dpkg returned an error code (1)
How do I remove gravetat completely? I don't care about trying to get it installed, if I can get it uninstalled.
Code:
sudo apt-get --purge remove gravetat
should purge the program
you can also try aptitude or dkpg if apt doesn't get rid of it
Code:
Code:
K-Server:/home/shelnutt/Downloads# apt-get --purge remove gravetat
E: The package gravetat needs to be reinstalled, but I can't find an archive for it.
K-Server:/home/shelnutt/Downloads# dpkg --remove gravetat
 Package is in a very bad inconsistent state - you should
 reinstall it before attempting a removal.
 gravetat
K-Server:/home/shelnutt/Downloads# dpkg --purge gravetat
dpkg: error processing gravetat (--purge):
 gravetat
No go :-/
look in the following directory :
$ cd /var/lib/dpkg/info
Now list files in following format:
packagename.*
$ ls packagename.*
Now open each file and find out line that read as follows:
$ /bin/sh -e
and replace this with
$ /bin/sh
Save and close all the files. Now run apt-get / dpkg command again to remove package:
$ apt-get --purge remove packagename
or
$ dpkg -r packagename
Let me know if that works for you (remember to backup files before making changes to them)
Code:
K-Server:/var/lib/dpkg/info# ls packagename
ls: cannot access packagename: No such file or directory
K-Server:/var/lib/dpkg/info# ls | grep packagename
K-Server:/var/lib/dpkg/info# ls |grep grav
gravetat.list
gravetat.md5sums
gravetat.postinst
gravetat.postinst~
gravetat.postrm
gravetat.postrm~
I then did what you said to the two gravetat.postinst and gravetat.postrm and now:
Code:
 gravetat
With no scripts:
Code:
shelnutt@K-Server:~/Downloads$ su -c "alien -d Gravetat-0.9.1-1.i386.rpm"
Password:
Warning: Skipping conversion of scripts in package Gravetat: postinst postrm
Warning: Use the --scripts parameter to include the scripts.
gravetat_0.9.1-2_i386.deb generated
Selecting previously deselected package gravetat.
(Reading database ... 290660 files and directories currently installed.)
 gravetat
  gravetat
0 upgraded, 0 newly installed, 1 to remove and 1024 not upgraded.
 gravetat
With scripts:
Code:
shelnutt@K-Server:~/Downloads$ su -c "alien -d --scripts Gravetat-0.9.1-1.i386.rpm"
Password:
 gravetat
let the scripts use only "/bin/true" as content.
And I really hope you learned your lessen to NEVER EVER use alien to build a .deb. NEVER.
If you must use rpms, make a .tgz from it and install in /usr/local (stow or whatever) or /opt
That worked!
Well I've converted a few before with alien and never ran into an issue. I'll be much more careful from now on.
I just need to get back to gentoo.
