- May 28, 2004
im building a budget rig and initially, i was gonna purchase this mobo
http://www.newegg.com/app/ViewProductDesc.asp?description=13-131-484&depa=0
but later, i found a cheaper product of the exact same performance specs, but with an unknown name (matsonic). the only difference i can notice is that its OEM
http://www.newegg.com/app/ViewProductDesc.asp?description=13-184-014&depa=0
the price difference is like $30 and im definitely aiming for the best bang for my limited buck. which should i stick with? would getting an OEM be bad? thanks
