- Feb 25, 2013
- Spring Hill, Florida
The other day a program I've used a bunch did a random disk wipe on my ssd (I didn't even know you could do that to an ssd.) I've used this program a bunch and it's never done this before... I read online it was "bug" some people were experiencing that turned the option on.
The common consensus was it's bad!
How exactly would it cause damage? The commenters were very vague "it'll shorten the ssds life span by causing unnecessary writes."
I was thinking say you have 100gb of space to "wipe" and you do 7 passes = 700gb's of write space and that's how you "shorten" the life span? Or does a program like this actually cause damage?
Needless to say I deleted said program and will be paying closer attention.
Now i'm using AVG's tuneup program... It cleans old registry, can scan had drives for errors, fix windows mishaps, and more! It's also smarrt enough (under the defrag section) to have the SSD unselected. You couldn't even select it if you tried. Ultimately I decided leave the defrag off even on my HDD and i'll do it ever few months if it needs it.
Could you guys try to newbify the definition of writing cycle on a drive? I read a few articles last night and I don't quite get it.
Is it safe every now and then to do a registry scan / clean? Checks your drive for errors? It looks like the tuneup program has a lot of nifty features! is it safe to use them? Do I have to worry about hurting my drives? In particular the SSD. (I have NO intention of ever using a disk wipe again... That was 100 percent accident.)
What's a registry defrag compared to a regular defrag?
