Wondering if you could help me bfore i go futher!!
My system is this:
3400 CG stepping Clawhammer
2x512mb OCZ PC3700 EB platinum edition
DFI NF3 UT Lanboy mobo
480W Antec True Blue PSU
x800 XT PE @ stock speeds
Basically i've done this so far
After a few blue scrrens have so far managed to get it up to
2.6ghz on the CPU using 1.552v (260x3 HTT)
Had to put a divider on the ram once i past 250HTT so i've set it to 9/10 (380)
Rams at 3,3,2,7 T1 with 3.0v
I'm going to change the T1 to T2 (after reaing your post again)
I'm going to increase the vcore allot more as i have phase change cooling and just wanted to see what was attainable at 1.55v. But my last system crash was sorted when i used the divider so makes me thing around 250 is my rams limit. So was wondering if you could tell me what kind of divider to use when i'm nearing 300HTT basically want to keep my ram as fast as possible!!
Hope you can help
Smokie
My system is this:
Hope you can help
Smokie
