- Aug 14, 2014
Took less time than your typical game crack
"DLSS Frame Generation doesn't seem to be hardware locked to RTX 40 series. I was able to bypass a software lock by adding a config file to remove the VRAM overhead in Cyberpunk. Doing this causes some instability and frame drops but I'm getting ~80 FPS on an RTX 2070 with the following settings:
2560x1440 res
HDR off
DLSS Balanced
DLSS Frame Generation ON
Ray Tracing Ultra preset
(I get ~35-40 FPS without Frame Generation and DLSS at Quality)"
"While there's definitely a performance gain on older cards with DLSS 3 frame generation enabled, it should be pointed out that it wasn't without its fair share of issues. The user experienced instability and frame drops so running frame generation on DLSS 3 won't get you the most optimized gaming experience at the moment since it is designed with GeForce RTX 40 graphics cards in mind. JusDax also hasn't really shared any images or the config file so we can't really test it or confirm this ourselves. What we did see in our own testing was that the frame generation switch can be toggled on and off on an RTX 30 and RTX 20 graphics card but we didn't see any difference in FPS or other performance metrics."
"Think speed, latency and counts. Matching the requirements grants access. This is all I can share."
NVIDIA DLSS 3 "Frame Generation" Lock Reportedly Bypassed, RTX 2070 Gets Double The Frames In Cyberpunk 2077
NVIDIA recently introduced its new DLSS 3 technology that adds a new feature known as Frame Generation on supported GPUs.
wccftech.com
2560x1440 res
HDR off
DLSS Balanced
