- Apr 22, 2004
Hello there,
I am putting together a new build (i5 4670k w/ asrock z87 extreme6) and I have already purchased this memory set: http://www.newegg.com/Product/Product.aspx?Item=N82E16820104340
However, this particular set is not listed on the "memory support list" for this board: http://www.asrock.com/MB/overview.asp?cat=Memory&Model=Z87 Extreme6
There are several supported sets that are VERY similar. In the past I never had issues with buying RAM so I didn't think to check this first (but it's been several years since i've built a PC).
Thus, is it critical that the memory be on the support list in order to work correctly? I kind of need to know because my CPU/MOBO is coming next week and I can RMA the ram now and have some by then.
Thanks for your help!
