ya then fold the flap inwards directly locking it in place against the inside wall. I used the pacman shaped clear window upside down so the blowhole isn't piped to the cpu but a 80mm fan blows right on the vid card. Drill a hole, use a fine blade on a jigsaw, then a pink dremel grinding wheel, or whatever u got, to smooth the inside edge. It can be seen I guess on the profile from the outside.
a clear window is the only way to go
I painted everything but the 1" of the top of the plate that has the standoffs that holds the mobo, I wish I had; gold.
Now i've got fans everywhere and I have turn knobs, and the light is usefull for gamng in the dark, and I wabnt a vid card cooler I want a 6 point toggle flip 3.5" for gaming.
http://www.bigfootcomputers.com/Mer...=PROD&Product_Code=2419CMOD&Category_Code=130
Can I get an all in one button, cause cooling is an all for games, or none for not situation, and I will have 6 fans after the vid cooler, incl the cpu cooler, besides my lights, and the psu fans, which deal with themselves, and the small MCH fan, which is always on ? This is another Q, and I don't even know if I can disconnect the Zalman cpu cooler from the mobo cpu_fan connector, for starters.
