The reason I got the Innovatek block was because I was too timid to use the four bolt method and it attaches with the six lugs on the socket. It did it's job, just not to my liking.
I however have created a problem. When installing my new waterblock, I let my screwdriver slip off the back of the case and gouge a hole in teh motherboard around one of the holes. I seem to have killed the sound on the board by doing so and it seems a tad unstable, not from heat or something that you usually think of, it's just that it decides to shut off and it does, or it will kick me offline, and it will not run windowsXP no matter what I do. I have had to revert back to windows ME because it's not as picky.
As far as the way it runs, it runs internet fine, seeing as how I'm here. hehe It runs prime95 fine, it runs memtest fine, it just at different times decides to do things out of the ordinary. I can overclock and run the same voltages as before, it just seems quirky.
I have reset the block thinking that might be it but I really believe the gash in the mobo is the culprit. Sometimes I even have to reset the cmos while holding the power button and turning on the power to the psu a couple times to get it to boot. It's like living with a ghost.
Oh well, I've ordered a new board, this time, no screwdrivers used and I will install the block with the motherboard out of the case. An expensive lesson learned, but it was a lesson learned nonetheless.
Don't install waterblocks with the mobo in the case!!!! If you do, don't use screwdrivers to hold the bolts in place!!!
